recessed steam radiator seals/washers
hamcrest
Member Posts: 4
I have an old Victorian house in Brooklyn and I'm trying to locate new gasket/seal/washer that connects the radiator to the wall plate at the pipe junction. They seem to be about 2" round, needs 4. None of the local plumbing supply stores have them.
Thanks, Jim
Thanks, Jim
Can you post a picture of that connection and the radiator? Most radiators are connected to a valve and, if a two pipe system, a trap at the other end.0
The 2 gaskets are visible here
That's not a wall plate. That is actually the end plate that is part of the actual radiator. Do you see any name on that radiator? If you can find a name, you can probably get replacement press nipples. Do they appear to be a composite material or a metal/brass material?
I see one bolt/nut at the top. Is there one at the bottom too? Those would allow you to draw the radiator and end plate together a little tighter and that may stop the leak, but be careful not to over tighten them and crack the cast iron.0 -
Thanks, Fred. Can't find a name on it, maybe I'll look for one on a less rusty piece, there's 4 more in the house.0
Was there a particular manufacturer in those days?0
By the time you’re done, you’ll have wished you just got a new convector @hamcrest...just get a new convector.1
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
