Interesting Hot Water Manifold
New England SteamWorks
New England SteamWorks Member Posts: 1,529
edited November 2018 in THE MAIN WALL
I just received some advanced photos for a hot water job I am going to look at soon. The manifold looks quite interesting, and I am wondering if anyone has any insights? Looks like I should be able to convert it to 3 zones, right now it is just one. There's a big expansion tank in the ceiling, which we'll of course remove.
Thanks!
newenglandsteamworks.com
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    Wow, nice cast from the gravity past! The three points of connection to the compression tank are neat too. Would get all the air to the tank somewhat effectively.
    STEVEusaPA
  • STEVEusaPA
    ...There's a big expansion tank in the ceiling, which we'll of course remove...
    Rut-roh...I wonder who has something to say about it...lol
    JUGHNECanucker1Matthiasrick in Alaska
    hot_rod Member Posts: 26,573
    Looks like the boiler has been replaced before? Nice collectible piece, that header.
  • Solid_Fuel_Man
    @STEVEusaPA that was at the forefront of my mind as well!
    STEVEusaPA
  • New England SteamWorks
    I am guessing there has been more than one replacement boiler since the original...
  • We haven't done a water boiler in a very long time, and we really didn't enjoy all the purging and radiator bleeding. Still, it was a pleasant change in the routine, and came out nicely.
    It's a wrap!
    That's quite a piece, judging by the gauge, it is old, old!
  • Solid_Fuel_Man
    Well you didn't paint your new copper brown to match! Steam guys.......
    New England SteamWorksCanuckerSeanBeans
  • kcopp
    kcopp Member Posts: 4,628
    What is there to prevent the boiler from condensing? I imagine w/ that much water content it will be in condensing mode for a good while.
  • STEVEusaPA
    Look at you 'slumming it' with a water boiler... Looks nice.
    Is that exp tank ok hanging like that?
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,313
    I'd be worried about the size of the compression tank too. If that's the typical gravity system, especially with columnar rads, they hold a lot of water. Fortunately they don't get too hot usually, but a tank bigger than a #30 usually is needed. I have had to use floor mounted tanks or 2 to 3 #30, or 60's in some systems.
    Steam can be a lot easier to installed in many ways.... you don't have to watch out for condensation or cold or hot shocking nearly as much.
    kcopp
  • Solid_Fuel_Man
    I just think those steam guys are not used to figuring the weight of water in their pipes! Think of the whole system as a wet return....minus the corrosion!
