Effects of light carbon monoxide poisoning?
nicholas bonham-carter
Member Posts: 8,577
The priestess at the Oracle at Delphi in Ancient Greece sat above a volcanic fissure, in the open air, inhaling the fissure’s “sweet vapors”, and going into a trance. In this state she was said to be able to foretell the future, or at least give good advice, and answers to questions put to her by such people as Alexander the Great.
Could a light dose of Carbon monoxide poisoning explain this trance?—NBC
I have also heard that there is a theory about how the rise of perceived hauntings and other supernatural phenomenon in the Victorian era is thought to have been at least partly caused by the rise in the use of gas lighting in homes. Everyone was getting subtly poisoned by their lights, and having strange visions and nightmares and hallucinations in the worst cases.
Could be....3 -
It certainly could!—NBC0
I believe it could do that as CO replaces oxygen in the blood and forms Carboxyhemoglobin
Ray Wohlfarth
Boiler Lessons0 -
sewage gases toodelta T said:I have also heard that there is a theory about how the rise of perceived hauntings and other supernatural phenomenon in the Victorian era is thought to have been at least partly caused by the rise in the use of gas lighting in homes. Everyone was getting subtly poisoned by their lights, and having strange visions and nightmares and hallucinations in the worst cases.
Could be....
I also think that inhaling the fissure’s “sweet vapors” might sear the inside of your nasal passages, the temp would be quite high
There have been many attempts to find a scientific explanation for the Pythia's inspiration. However, most commonly,
these refer to an observation made by Plutarch, who presided as high priest at Delphi for several years, who stated that her oracular powers appeared to be associated with vapors from the Kerna spring waters that flowed under the temple. It has often been suggested that these vapors may have been hallucinogenic gases.
Recent geological investigations have shown that gas emissions from a geologic chasm in the earth could have inspired the Delphic Oracle to "connect with the divine." Some researchers suggest the possibility that ethylene gas caused the Pythia's state of inspiration. Traces of ethylene have been found in the waters of the Castallian spring, which is now largely diverted for the town water supply of the town of modern Delphi. However, Lehoux argues that ethylene is "impossible" and benzene is "crucially underdetermined." Others argue instead that methane might have been the gas emitted from the chasm, or CO2 and H2S, arguing that the chasm itself might have been a seismic ground rupture.
An alternative theory based on review of contemporary toxicological literature indicates that it is oleander that causes symptoms similar to those of the Pythia. Pythia used oleander as a complement during the oracular procedure, chewing its leaves and inhaling their smoke. The toxic substances of oleander resulted in symptoms similar to those of epilepsy, the “sacred disease,” which amounted to the possession of the Pythia by the spirit of Apollo, an event that made the Pythia his spokesperson, and subsequently, his prophetess. The oleander fumes (the "spirit of Apollo") could have originated in a brazier located in an underground chamber (the antron) and have escaped through an opening (the "chasm") in the temple’s floor. This hypothesis perfectly fits the findings of the archaeological excavations that revealed an underground space under the temple. This explanation sheds light on the alleged spirit and chasm of Delphi, that have been the subject of intense debate and interdisciplinary research for the last hundred years0 -
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 987 Plumbing
- 389 Solar
