convert water heater to holding tank
hotheat
Member Posts: 1
I am trying to convert a 75 gal water heater to a holding tank for a boiler system. Where can I get the piping to connect to the old water heater element holes? Everything I have tried does not fit correctly.
What he said^^^. All I've seen are 1" straight thread as well, and 1" NPT will seal under residential pressures. A good anaerobic thread sealant definitely helps seal better than tape and dope IMO, I use Permabond LH150 or Loctite 5670
Are you referring to the square flanged elements? As has been stated, the round elements are 1" straight pipe thread.
If they are square, have your local machine/fabrication shop make you some adapter plates. May even be able to get 1-1/4 FPT then!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
