convert water heater to holding tank
hotheat
hotheat Member Posts: 1
I am trying to convert a 75 gal water heater to a holding tank for a boiler system. Where can I get the piping to connect to the old water heater element holes? Everything I have tried does not fit correctly.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,009
    Hello, For most electric heaters, those holes are one inch thread. They may be straight rather than tapered thread, as the elements use a gasket to seal, but I've never had a problem making them water tight using one inch tapered pipe fittings. o:)
    Yours, Larry
    Solid_Fuel_ManCanucker
  • GroundUp
    GroundUp Member Posts: 2,465
    What he said^^^. All I've seen are 1" straight thread as well, and 1" NPT will seal under residential pressures. A good anaerobic thread sealant definitely helps seal better than tape and dope IMO, I use Permabond LH150 or Loctite 567
  • Solid_Fuel_Man
    Are you referring to the square flanged elements? As has been stated, the round elements are 1" straight pipe thread.
    If they are square, have your local machine/fabrication shop make you some adapter plates. May even be able to get 1-1/4 FPT then!
    Canucker
