Wiring White Rodgers hydronic valve
hdalal
Member Posts: 1
How do I wire two thermostats to a White Rodgers two wire hydronic valve?
This is how I would do it:
What do you hope to achieve? One stat will still over shoot.0
If you want two thermostats, consider getting a thermostat that incorporates a remote sensor. That way, the internal sensor and the remote sensor average, or you can do it the way Alan shows.
Curious to know why you want two thermostats, but I've had some different scenarios where it would work.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
