Wiring White Rodgers hydronic valve
hdalal
hdalal Member Posts: 1
How do I wire two thermostats to a White Rodgers two wire hydronic valve?
  • This is how I would do it:
  • unclejohn
    unclejohn Member Posts: 1,833
    What do you hope to achieve? One stat will still over shoot.
    HVACNUT Member Posts: 7,454
    Agree with @unclejohn
    Are you looking to wire 2 thermostats to the same valve?
    If so, why?
  • Solid_Fuel_Man
    If you want two thermostats, consider getting a thermostat that incorporates a remote sensor. That way, the internal sensor and the remote sensor average, or you can do it the way Alan shows.
    Curious to know why you want two thermostats, but I've had some different scenarios where it would work.
