2 pipe steam
Just looked at an apartment building where a few of the radiators had the valve (inlet) up high and the trap down low on the same side of the rad. I’m not sure I’ve ever seen this before? From what I’m told, they work and I don’t see why they wouldn’t? Is this common? Wrong?
Steve Minnich
    Jamie Hall Member Posts: 26,832
    No reason why it won't work, @Stephen Minnich -- I have half a dozen of those in one of the places I care for, and they seem to work just fine.
    Steve Minnich
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    Thank you, Jamie.
    Steve Minnich
    Steamhead Member Posts: 18,194
    Typical Vapor setup. The steam enters at the top and displaces the air downward. When it gets to the bottom it doesn't matter which side the trap is on.
    Consulting
    Steve Minnich
  • Steve Minnich
    Thanks Frank. I was thinking like air like Dan teaches so I thought it was cool but wanted to verify.
    Steve Minnich
  • gerry gill
    gerry gill Member Posts: 3,083
    yes, fine..the rule if i remember right, was as long as it wasn't three times its height in length it would work fine. If memory serves that was the OE vapor rule.
    gwgillplumbingandheating.com
    Steve Minnich
