2 pipe steam
Steve Minnich
Member Posts: 2,868
Just looked at an apartment building where a few of the radiators had the valve (inlet) up high and the trap down low on the same side of the rad. I’m not sure I’ve ever seen this before? From what I’m told, they work and I don’t see why they wouldn’t? Is this common? Wrong?
Steve Minnich
No reason why it won't work, @Stephen Minnich -- I have half a dozen of those in one of the places I care for, and they seem to work just fine.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England-1 -
Thank you, Jamie.
Steve Minnich0 -
Typical Vapor setup. The steam enters at the top and displaces the air downward. When it gets to the bottom it doesn't matter which side the trap is on.All Steamed Up, Inc.
Consulting-1 -
Thanks Frank. I was thinking like air like Dan teaches so I thought it was cool but wanted to verify.Steve Minnich0
yes, fine..the rule if i remember right, was as long as it wasn't three times its height in length it would work fine. If memory serves that was the OE vapor rule.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.-1
