Question About Glycol
grahamjohnson54
Member Posts: 2
I have an old house that has a natural gas boiler with a closed loop water system for heat. I live in Southern Oregon where freeze protection is of low concern. Can I get away with refilling the system with water and inhibitor mix with no glycol in the system? It would obviously save me a lot of money. Thanks. My system size is roughly 160 gallons if that impacts your decision. Thanks again.
No outdoor piping and never unattended. Awesome thanks.0
do you have a service provider who knows your system inside and out? I'd ask him(her).. just saying...0
Why was the glycol in it originally?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
What @Solid_Fuel_Man said would be my question0
If freezing is not an issue, no glycol. if there is not constant make up water inhibitors may not be needed. There are many commercially available inhibitors that could work for you. Silver King is one brand. Just be sure they are environmentally friendly. Remember, whatever you put in there, will eventually need to come out.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
