Removing hot water radiators
zoom
zoom Member Posts: 72
I need to temporarily move all of the old hot water radiators away from the wall so I can work behind them. Each radiator has a union where hot water comes in so that should be relatively straight forward to disconnect. However, the return sides just go down to the basement below and are piped in - no unions, but the pipe is accessible from the basement.
What is the best way to move these radiators? Is it possible to disconnect one end only and then "swing" the radiator 90 degrees away from the wall but still connected at the other end? There must be a way to do this without cutting the pipe and the having to reconnect?
  • JUGHNE
    JUGHNE Member Posts: 11,508
    Could there be LH/RH nipples on the outlet?
    If you swing them away you could be facing a possible leak in the future as you either tighten or loosen a nipple and then return it back may do the opposite. Provided nothing snaps off.
    A close picture of the return side might help.
    Steamhead Member Posts: 18,184
    Take some pics and post them here- let's have a look.
    Consulting
  • zoom
    I will get some pics when I return to the house in a few days. Any help is much appreciated.
  • zoom
    Attached are two pictures of the set up I have on the radiators throughout the house.
  • JUGHNE
    Could that outlet 90 have a union fitting with a spud into the rad?
    It looks to have ears on it. I would clean it up, spray some PB Blaster or Kroil on it and try to unscrew it.
    The nipple going into the rad might be brass, a magnet would tell you.
    Steve Minnich
  • zoom
    OK I'll try that and report back.
    Jamie Hall Member Posts: 26,798
    I agree that it looks like it might be a union. If so, when you go to unscrew it, remember that it is not always obvious which half of the union the threads are on, and thus which way to go to unscrew it... (though I'd guess on this one that the nut is on the elbow, not on the spud).
  • JUGHNE
    I would guess you put a wrench on it and push down towards the floor.
    On the inlet valve I would try pulling up on the wrench.
    For both I would try to cut the paint with a dental pick.
  • zoom
    I was not able to free the radiator, it is not a union I think
  • delta T
    delta T Member Posts: 884
    There has to be a LR nipple or a union in it somewhere or they would never have gotten it together. My bet is that the nipple going the rad is a LR. Whether it moves or not is another story.....
    The ears on the 90 are likely there to mark which side is the left handed thread on the install, nipple and 90 were proabably sold together, doubt the threads on the rad are left handed, so lift your wrench up (ccw as related the rad) and see what happens...
    JUGHNE
  • zoom
    I am working on the radiators now.
    I had a new Viessmann VITOCROSSAL 300 CU3A installed. I am getting a C1 error code. Any one familiar with this code and the fixes? Still trying to locate a tech to come and take a look.
  • delta T
    That is a communication error with your EA1 extension module. Check the wiring connections first, past that you will probably want a pro who knows Viessmann come out and take a look. Where are you located?
