Need Operating Manual for American Standard gas boiler
pjn3
Member Posts: 5
Hi- recently moved into a 1920s-era house in Baltimore. Need O&M manual for American Standard gas boiler G-407 / Series 1BN-J1. Any help appreciated...thanks!
Luckily you are in the hometown of one or the great experts on this site-Steamhead.
Look in the find a contractor area here, and contact him, so he could check it over and show you how to do simple maintenance.—NBC0 -
ironically we have a Series 1BN-J2 and are also in Baltimore. please attach a few photos so we can see how similar they are?
we have a 3BN-J2, but I assume there are similarities
+1 for @Steamhead0
but if you can post a pic of the boiler that would help
@pjn3 @Koan they're probably the same basic model but pjn3's has two more sections than Koan's.
Give us a call- 410-321-8116.All Steamed Up, Inc.
Consulting0 -
Update- talked to the OP this afternoon, turns out we've worked on this system for the previous owner. It was originally a Kriebel but was converted using Trane thermostatic traps, something we've seen frequently around here. We'll get him up to speed.All Steamed Up, Inc.
Consulting2 -
@Steamhead - appreciate chatting yesterday. Attached note from our home inspection. Can you confirm these are correct locations to drain and add water back into boiler? thanks...I'll upload couple photos of boiler in next post(s)0
Ah yes, the infamous 47-2 water feeder. We'll need to replace that with a 21st-century control set that tracks water usage. The report was correct as far as it goes, but there's more to it. We'll go over it when we see you.All Steamed Up, Inc.
Consulting0 -
sounds good; i'm just concerned that will need the heat/boiler running prior to when you're available. if i can limp along adding and removing water weekly, i'd feel more confident. thanks0
You can. Always make sure the glass is half full when the boiler is off. Only flush out enough water from the 47-2 so it runs clear. Check it every day until we come, and call if there are any issues or questions.All Steamed Up, Inc.
Consulting0 -
@pjn3 I want you to know I have a degree in Mechanical engineering and am a proficient DIY person, but I had @Steamhead come out to help us. He really knows his stuff. He is who I would call without hesitation!0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
