Tell me all about it.
Harvey Ramer
Member Posts: 2,239
This copper tank. I just removed it from a basement. It was installed vertically and plumbed inline prior to the electric water heater.
That's called a "range boiler", and it used to be fed with either a side-arm heater on a boiler or a coil in a stove. Hot water thus generated was stored in the tank.
They may be using it as a tempering tank now, for incoming water to warm up a bit before it hits the WH.All Steamed Up, Inc.
Consulting2 -
What @Steamhead said. Used to see them in old kitchens connected to the stoves. My grandfather had something like that heated by some type of kerosene heater that stored the kero in a glass bottle. My father was convinced they would break the bottle and burn the house down.0
Had a setup like that in the place I care for (it's been gone many years now). It was heated from a coil in the wood/coal stove (a Glenwood) which was used for cooking. I can't for the life of me figure out how anyone could stand cooking in a kitchen on a day like today (85 and 90 percent humidity) with a coal stove going... but they did.Br. Jamie, osb
And they were dressed head to toe to boot!Jamie Hall said:Had a setup like that in the place I care for (it's been gone many years now). It was heated from a coil in the wood/coal stove (a Glenwood) which was used for cooking. I can't for the life of me figure out how anyone could stand cooking in a kitchen on a day like today (85 and 90 percent humidity) with a coal stove going... but they did.
Reminds me of those old pics of people on the boardwalk in 3 piece suits-90+ degrees, high humidity...
I've got the heater from a wood stove if you want a matching set.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
I know we sometimes get sentimental about the older equipment, controls, burners, etc. but I would go straight to the scrap yard with that to ease the burden in my wallet.
Did I just commit heating blasphemy?0 -
I must polish all that copper....it's calling my name. @ChrisJ1
The stove attachment I have is cast iron or something. Not copper.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
I was referring to the tank posted by the OP, I only tagged you for the funny about polishing.
Now if you want to challenge me to polish cast iron I will accept that challenge.1 -
I saw on in a basement standing up on a stand, below it was a gas burner, when you wanted hot water you went down, struck a match and lit the burner, in a little while you had hot water, then hopefully you didn't forget to go back down and shut it off.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
