Insulation ?
RayH
Member Posts: 101
I'm installing radiant heat in a basement slab. What is the prefered insulation to use ? Thank, Ray
im thinking anything with a .5 r value or better0
You absolutely don't want any product that claims reflective properties like "double bubble".
I would recommend any closed cell product with a weight rating of 25 psi or better. Dow Blue Board or field applied sprays are commonly used.
The energy code should call out the required R-value for your zone. R-10 (2") is a good place to start.
Albert Einstein1 -
I think some codes now require 2" minimum. About 5 per inch R for the blue and pink foam boards, and they are intended for under slab use.
Or the CreteHeat products with the knobs to hold down he tube, you get a vapor barrier included with those products.Bob "hot rod" Rohr
2" XPS is R10 and what I use as a minimum on all installations. As was mentioned. That "double bubble" crap is a joke at best0
Ray, am a newbie so do not know if you are DIY or pro.
If it is DIY you can sometimes find Used Dow Roof mate EPS that a roofer has taken off a flat roof, it is 4" thick stepped and has a good PSI, you can walk on it with boots and not leave heel marks.
You can lay it on a vapor barrier, tape the joins and have R20 for a lot less than the big box hardware stores. You might check with your local inspector to see if he will accept it. He should it is excellent closed cell material.0 -
Dennis, why would Hydrofoam have a different response to the movement of heat, than say XPS, or other closed cell foam?
Trying to learn as much as possible about insulation thank you.0 -
^ it doesn’t. At least not more so than any other similar product as hydrofoam.
As a matter of fact a tube fully encompassed by the concrete is more effective at heat dispersal/ exchange than tube laying on the foam inslation covered in concrete. A fraction of the tube unless it floats off the foam during pouring is against the insulation medium.1 -
Has anyone ever used Rapid Grid for Viega ?0
