Two stage gas valve conversion
The Steam Whisperer
Member Posts: 1,313
I am looking at at 630,000 input atmospheric boiler on which I want to install a two stage gas valve. I know I have seen some before which looked like they would work well, but can't find the info. I know some of you guys have installed them,....what did you use and how did they do? IIRC many had a fixed low rate ( 1.7" WC or about 75% capacity) which would work fine for this app. I think the factory step opening valve on these models are 1.7 step and 3.5 full fire.
Thanks for your help
What boiler is it?
Have you checked if the manufacturer offers a 2 stage gas train?0 -
It a peerless 64 series... no two stage gas train.To learn more about this professional, click here to visit their ad in Find A Contractor.0
https://www.robertshaw.com/Products/Heating/Gas-Valves/700-064/?cat=2147484264
I think this is what you want0 -
Yep, that's the one. I had seen it before and just couldn't refind it!To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 167 Indoor-Air Quality
