can you add on demand to an older gas boiler for radiant baseboard heat?
beoutside
Member Posts: 9
We have an older system in a small house. It is a Valliant boiler closed-loop radiant floor baseboard with the individual on/off valves at each heater. Is there a way to add on-demand hot water?
Thank You
Donny McClure
Carpenter/ home Plummer and mechanic
Thank You
Donny McClure
Does the boiler have a plate where a tankless coil could be installed? Pictures?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
No, just the gas and water in on the back, flush on the front bottom. We are demoing the pantry and looking to save space and thinking of replacing the electric water heater that is as old as I am.
Thank You
Add an indirect water heater with priority.0
"On demand" is going to cause a lot of short cycling for the poor boiler on short bursts of hot water just for hand washing or whatever. It can be done but I would go the indirect route like has been mentioned above so you have some storage0
Yes , that is the way it was vented when we bought the house. Flex pipe to an old chimney.0
Appreciate all the input, this old house did a video on adding an indirect with all the correct valves and safety measures..... I guess we can bypass saving space and just put the indirect were the old water heater is. On the video, the broiler used was larger than ours and had a side plate accessing the water they used to heat the house. With our baseboard radiant system, it is much smaller heating baseboard heaters, approx 40 feet total on one floor. We also heat with an efficient airtight wood stove.0
Ill double check but think our boilers BTU's is only 50000. Someone online recommended a minimum of 100000 for it to pump out hot water at an acceptable and predictable rate. Is that the case? Maybe we should just ad a tankless hot water system?0
Do you need 100000 Btus an indirect system to work well?0
Your existing electric heater is probably 16,000 btu. Your 100,000 is probably derated to 80,000 btu. An indirect should do the trick"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Does your broiler need to pump out a minimum of 100000 Btus, I meant!0
I’ll check but I think our broiler is 60000 BtU and I hear you need 100000 btu broiler as a minimum ? To work with an indirect0
Aren't broilers used in the kitchen? According to the ID tag photo above, your boiler's output is 50k which is plenty for your DHW needs when on priority. You won't get any space heating while on a DHW call, but that's not typically an issue unless you plan on using a million gallons of hot water0
Thank you ! I’ll broil you up some rib eyes0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
