"HVAC Pub"- no, I didn't make this up
Steamhead
Steamhead Member Posts: 17,929
Found this place at Chicago Midway Airport, where Southwest operates from for Chicagoland. Apparently this is a branch location- the main location is near Wrigley Field:
Good burgers!
Consulting
Erin Holohan Haskell
  • newagedawn
    newagedawn Member Posts: 586
    what type of havc did it use?
    "The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,649
    This place is worth the trip: https://www.powerhouseeatery.co/
    You dine under the remnants of the water-tube boiler. The menu covers are made of old steam-products literature. And the food's pretty good!
    Retired and loving it.
    Probably a rooftop unit- I didn't have time to look.
    Consulting
    Solid_Fuel_Man
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,360
    Nice find! And there's also this bar/restaurant: The Boiler Room
    President
    HeatingHelp.com
    Wonder what heats that building now? :(
    Consulting
  • GroundUp
    GroundUp Member Posts: 2,393
    We consolidated an old WW2 weapons factory called FMC or United Defense, depending on the time frame, in Fridley, MN in 2014-15. Took it down from the original 2 million square feet to the current 475,000 sq ft. The original boiler room from 1942 is no longer part of any building, but remains free standing and I'm told is being converted to a brewhouse of some sort. I was there to the 475k facility to cut in some 10&12" OS&Y valves about a month ago and saw a crew working on the old boiler house across the property. Still sporting the old 120ft tall brick stacks, should be a pretty cool place
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,279
    Heck, that's only 2 hours away from where I live. Next time i'm up that way I'm making a stop.
    Thanks for the tip!
  • DanHolohan
    It's right up your alley, Harvey.
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    That place looks cool Dan. Pre-war era industrial is both art and function. Love those big HXers.
  • DanHolohan
    And it’s right on the highway. I drive by it for years before checking it out with friends at nearby convention. Sure glad we did.
