"HVAC Pub"- no, I didn't make this up
Steamhead
Member Posts: 18,209
Found this place at Chicago Midway Airport, where Southwest operates from for Chicagoland. Apparently this is a branch location- the main location is near Wrigley Field:
Good burgers!
Good burgers!
Consulting
Consulting
1
what type of havc did it use?"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
This place is worth the trip: https://www.powerhouseeatery.co/
You dine under the remnants of the water-tube boiler. The menu covers are made of old steam-products literature. And the food's pretty good!Retired and loving it.0 -
Probably a rooftop unit- I didn't have time to look.newagedawn said:what type of havc did it use?
Consulting1 -
Wonder what heats that building now?
Consulting0 -
We consolidated an old WW2 weapons factory called FMC or United Defense, depending on the time frame, in Fridley, MN in 2014-15. Took it down from the original 2 million square feet to the current 475,000 sq ft. The original boiler room from 1942 is no longer part of any building, but remains free standing and I'm told is being converted to a brewhouse of some sort. I was there to the 475k facility to cut in some 10&12" OS&Y valves about a month ago and saw a crew working on the old boiler house across the property. Still sporting the old 120ft tall brick stacks, should be a pretty cool place0
Heck, that's only 2 hours away from where I live. Next time i'm up that way I'm making a stop.DanHolohan said:This place is worth the trip: https://www.powerhouseeatery.co/
Thanks for the tip!0 -
It's right up your alley, Harvey.Retired and loving it.0
That place looks cool Dan. Pre-war era industrial is both art and function. Love those big HXers.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
And it’s right on the highway. I drive by it for years before checking it out with friends at nearby convention. Sure glad we did.Retired and loving it.0
