O-S Fitting
Henry
Member Posts: 998
The Northern Electric building had a one pipe gravity system for its 8 floors. The heated water would go to the top floor ceiling and spread out along the outside walls. There would be a pipe going down which would have two O-S tee (like monoflow) for each radiator on each floor. Each down main one would connect to a large return going into the boiler room building which was adjacent to the U shaped main building. As it was converted to multi use rental units, I installed Danfoss thermostatic valves on the radiators by moving them 10 inches from the O-S tee.
I did have a picture of the TY somewhere, but could not find it this morning.0
I once found on of the 'Unique' valves made by honeywell, Trying to find a pic for it now....we'll see. P.29 in Classic Hydronics.0
For those who don't remember, Northern Electric was the Canadian manufacturing unit for Bell Telephone, like Western Electric was for AT&T in the U.S. That building is probably built as well as the equipment that was made there. NE morphed into Northern Telecom, which collapsed recently.All Steamed Up, Inc.
Consulting0 -
This is why I love you guys.Retired and loving it.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 944 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
