O-S Fitting
Henry
Henry Member Posts: 998
The Northern Electric building had a one pipe gravity system for its 8 floors. The heated water would go to the top floor ceiling and spread out along the outside walls. There would be a pipe going down which would have two O-S tee (like monoflow) for each radiator on each floor. Each down main one would connect to a large return going into the boiler room building which was adjacent to the U shaped main building. As it was converted to multi use rental units, I installed Danfoss thermostatic valves on the radiators by moving them 10 inches from the O-S tee.
  • STEVEusaPA
    STEVEusaPA Member Posts: 6,506
    Come on Henry, you're not new here...where are the inside pictures...:)
    steve
    delta TCanucker
  • Henry
    I did have a picture of the TY somewhere, but could not find it this morning.
  • delta T
    delta T Member Posts: 884
    I once found on of the 'Unique' valves made by honeywell, Trying to find a pic for it now....we'll see. P.29 in Classic Hydronics.
    Steamhead Member Posts: 16,832
    For those who don't remember, Northern Electric was the Canadian manufacturing unit for Bell Telephone, like Western Electric was for AT&T in the U.S. That building is probably built as well as the equipment that was made there. NE morphed into Northern Telecom, which collapsed recently.
    Consulting
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,526
    This is why I love you guys.
    Retired and loving it.
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,284
    Ditto!
    President
    HeatingHelp.com
