High Efficiency Boiler Fan Test
rbeck
Member Posts: 56
What is your process to test the fan on a high-efficiency boiler to determine a fan or control problem? I know to remove the 4 wire connector and the fan should ramp to 100% providing there is 120vac to the fan.
I think those table top simulators that reps have can modulate the fan. They are used for control training classesBob "hot rod" Rohr
I know you can get controls to exercise furnace ECM blowers, if they interface the same way one of those might work, possibly with a harness adapter. If not, they're probably vendor-specific & would need a tool from the mfgr (or possibly the motor mfgr).0
Assuming we mean furnace not boiler.0
I was thinking that the inducer motor might be a cousin of the ECM blower motors, but the more I think about it, that's probably not the case. My guess now is that it's a custom integrated motor control so no bets outside the mfgr; but an analog control signal (PWM, 2-10V, 4-20 mA in order of my guess at probability) isn't outside the realm of possibilities. A multimeter and study of the schematics might tell us more.
Which boiler? A service manual might be Googleable.
