Gas/Steam Boiler with Fresh Air Intake
mroberts5
mroberts5 Member Posts: 76
Is anyone aware of any gas fired steam boilers (100k btu range) that have an option for a fresh air intake, which would eliminate the need to provide standard ventilation for a basement?
    Steamhead Member Posts: 18,508
    Any boiler with a Carlin EZ-Gas burner can be set up for outside air.
    Is 100K the Input or Net rating?
    Consulting
  • newagedawn
    newagedawn Member Posts: 585
    its not the boiler that needs the fresh air its the burner and as steamhead said any carlin ez can adapt a fresh air intake, they come in kits, most supply houses carry them
    "The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
    HVACNUT Member Posts: 7,454
    You can also use "Fan In A Can".
