Gas/Steam Boiler with Fresh Air Intake
mroberts5
Member Posts: 76
Is anyone aware of any gas fired steam boilers (100k btu range) that have an option for a fresh air intake, which would eliminate the need to provide standard ventilation for a basement?
Any boiler with a Carlin EZ-Gas burner can be set up for outside air.
Is 100K the Input or Net rating?All Steamed Up, Inc.
Consulting0 -
its not the boiler that needs the fresh air its the burner and as steamhead said any carlin ez can adapt a fresh air intake, they come in kits, most supply houses carry them"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
You can also use "Fan In A Can".0
- 167 Indoor-Air Quality
