Thermostat off, burner runs anyway
saxpoet
Member Posts: 1
I'm new to steam heat. This is a 5 year old Burnham, single pipe system. Hot water is an independent electric heater. Ever since putting the programmable Honeywell thermostat to 'off, the burner still fires up and runs a few minutes at a time, more than once a day. Is this normal?
Look on the right side of the boiler. Is there a grey rectangle control? Pull the cover and turn the temp to 140.
If its oil fired, it's not a bad idea to have the system cycle to keep the flue passages dry.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
