navien manifold dyi
jvboyle
jvboyle Member Posts: 2
Hi everyone , I'm a home owner installing a new Navien 240 Combi Unit. My local supply house didnt have the Pre-made manifold so i made my own. My question is , On the return , i used a standard 1'' T and i'm not sure if i should have used a monoflow or a Venturi Tee .....Any advice would be appreciated
larger View
  • Danny Scully
    Danny Scully Member Posts: 1,465
    Standard tee is the right fitting. Good luck!
  • Ironman
    Ironman Member Posts: 7,903
    edited May 2018
    Like this:
    The boiler circulator produces circulation through the boiler and another circulator(s) produces flow through the house (primary) loop.
    Regular Tees, absolutely no Monoflo or Venturi Tees.
    Bob Boan
    Rich_49
  • jvboyle
    THanks , Ill post some pictures when im all plumbed in !
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    .. They use a 1 1/4" , run and spacing of the tees are critical ... No taps for purging the boiler or for a tridicator gauge ... No dielectric unions ... Venturi tee , wrong system , forget about .. Rip it out , make it easy , order the manifold ... Do it right grass hopper
