Terra-cotta colored condensors
the_donut
Member Posts: 374
I assume black paint on coil fins is for better heat transfer (a little bit of coil cleaner will eat the paint, so I doubt it is for corrosion control). I know it’s only a 4% increase on the radiation side (I assume convection is dominant heat transfer mode). Besides being more visible, and possibly clashing with scenery, why not have terra-cotta colored fins on condensor coils? Has it ever been done?
DO NOT EVER PAINT THE COILS OR FINS!!!!!!!!!!!!!! EVER!!!!!!!!!!!!!
Had that done at a commercial customer, the unit ended up with high head., and it was not repairable.
You can take the jacket off carefully and paint that separately if you want.0 -
I am just wondering out f the box, why some are painted black, or anodized instead of terra cota. Other than aesthetics.0
Depends on the manufacturer and some have an option for a factory coating to protect against salt corrosion if it will be near the shore.
Most are plain copper tubing wrapped in aluminum fins.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
