Heat Exchanger
alanm
alanm Member Posts: 149
What is average cost (material only) for a heat exchanger for a Crown boiler KSZ200. thanks Alan
  • lchmb
    lchmb Member Posts: 2,997
    we dont discuss pricing on the wall...
    kcoppGBartdelta T
  • STEVEusaPA
    You can call Crown and ask them. The true cost depends on the amount of labor needed, depending on your situation.
    I wonder why do you need it replaced.
  • GBart
    GBart Member Posts: 746
    I think you mean a boiler block, depends on if it's under warranty, you would have to check with a supply house, if everything else has 10+ years go all new.
