Need Radiator/Convector Carpentry Ideas
New England SteamWorks
Member Posts: 1,528
I have a customer with steam heat on the 1st floor, and electric baseboard on the 2nd. This spring they'd like to convert the 2nd floor to steam for obvious reasons.
Oddly, one of the rooms has a piece of 1" black pipe running from it down to the basement. I am not quite sure it was intended for steam because the depth in the basement is a few inches too much to allow for pitch back to the main, but I can't guess at it's purpose otherwise. There's no plugged Tee on the original main either.
Anyway, the room in question has a built in wall cabinet with drawers and such on top of the pipe (see picture). The 3 drawers will obviously have to come out, but I am a little worried about the radiator being buried back in there and not heating the bedroom. One thought is to just put canning over the opening. The second thought is to only have openings at the top and bottom in an attempt to get some convection/air flowing out into the room. Thoughts?
You can just see the stubbed up pipe underneath...
newenglandsteamworks.com
Is it just this 1 room getting a steam rad? What’s to the right of the dresser, a bench?0
First question- is the pipe big enough to supply enough steam to heat the room?
If so- any reason you can't go horizontal under the drawers and put the rad under the window?All Steamed Up, Inc.
Consulting0 -
Are those ceramic tiles under that cabinet? Maybe the location where an old gas fireplace use to be? Any signs of brick on the sides or back that might indicate a chimney was removed?
I'd be inclined to remove the cabinet in total and install a free standing radiator.0 -
The tiles are linoleum, the 1" pipe will handle things. They like the built in. If I went horizontal to the window bench I'd loose that bottom drawer, and the drawers under the windows too.New England SteamWorks
newenglandsteamworks.com0 -
So what are you proposing exactly?0
I am proposing @Danny Scully that you super-smart guys weigh in on how to best attach a radiator to that pipe and heat the room!New England SteamWorks
How about taking that pipe straight up @New England SteamWorks and adding some radiation on top of those three drawers with maybe some decorative cover over it. If need be, a radiator fan in there to move the air?0
That's an interesting idea @Fred. See, I knew you guys were smart. Keep 'em coming!New England SteamWorks
Well I’m confused, are you more concerned with keeping the drawers or installing a radiator? That’s what i meant. Did you have an idea that saved the drawers and you were just wondering how the grilles should be situated? I would extend the runout to the right under the window and install a cast iron convector. You’d lose whatever draw is under the window, but you could still keep the face of the draw where the runout begins and use it as an access panel.0
No, they're not concerned about loosing those 3 drawers.New England SteamWorks
So you don’t like my convector idea?
Go with your idea then: remove the cabinets, install free standing rad, utilize cover techniques found in EDR. 0 -
How’s wall space? Would a princess unit work?0
What's a Princess unit? And yes @Danny Scully I do like your idea. But it does seem like a little more work...New England SteamWorks
Put the radiator on (e.g., http://www.steamradiators.com/orderingpages/charlestonpro.html) or recessed in the wall where the person is standing in the photo. Then the cabinet can stay. (Just make sure there is clearance for the drawers to open.)1
Is there such thing as a steam radiant ceiling panel?0
Princess on page 71. A tube style wall mount. Lots of these around my neck of the woods. Got a building where 10 of these aren’t in use.0
Ok, how competent is the carpenter that would do the work?
I say keep everything.
Go under the window with some kind of convector or even a small rad.
Shorten the drawer depth to allow clearance for whatever you put in there. Cut out the baseboard trim to allow for an air intake. Possibly add some sheet metal to create a duct of sorts. then add slots or a grille in the top of that window seat.
They lose some drawer space, but the impact should be minimal. The whole idea depends on the skill set of the people involved.0 -
It's in!
Nice! Will there be something covering the opening or does it stay as is?
What do you estimate the BTU output of the radiator is, when you factor the cabinet design and the color?0 -
You can even make cuts on the top and install nice looking registers. I’d warn your customer that heat from seam radiator can warp the cabinet though0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
