Tekmar 356 and ECM circulator
Does Tekmar make a similar control to the 356 that would work with a high-efficiency ECM circulator such as the Alpha or Viridian? The 356 is such a nice control for injection mixing, but I'm trying to use low energy circulators as much as possible.
  • Zman
    Zman Member Posts: 7,609
    With the introduction of the taco I series mixing valves, I am not sure why you would do injection mixing.
    I think that most delta t circs will do mixing with on board controls.
    The veridian and apha circs are pretty big for most injection applications
    Albert Einstein
    Rich_49
  • try2hard
    try2hard Member Posts: 26
    Sorry I had that post typed long ago and saved as a draft. I actually did decide to go with an i-series 2-way valve w/odr. That saves me an extra circulator and some kWhs.
    Moderator if you can delete, please do. I don't see an option available within edit post.
