Tekmar 356 and ECM circulator
try2hard
Member Posts: 26
Does Tekmar make a similar control to the 356 that would work with a high-efficiency ECM circulator such as the Alpha or Viridian? The 356 is such a nice control for injection mixing, but I'm trying to use low energy circulators as much as possible.
With the introduction of the taco I series mixing valves, I am not sure why you would do injection mixing.
I think that most delta t circs will do mixing with on board controls.
The veridian and apha circs are pretty big for most injection applications"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
Sorry I had that post typed long ago and saved as a draft. I actually did decide to go with an i-series 2-way valve w/odr. That saves me an extra circulator and some kWhs.
Moderator if you can delete, please do. I don't see an option available within edit post.0
- 15.8K Strictly Steam
