Summer water heating solution
Jon_blaney
Member Posts: 334
Looking for a summer water heating solution. I am considering an indirect heating solution with a electric back-up. An indirect is a great heating season solution but keeping the boiler on all summer is a waste. My fuel choices are electric or oil, no gas available. Anyone have experience with these? I know that the best solution is probably a HPWH and PV panels but I am not well situated for solar.
Electric is expensive but easy to maintain. We have hard water in my neck of the woods and scale builds up pretty quickly from the high temperature of the elements so flush the tank every year or so.
Another thing I dont like about electric is the slow recovery time. Gas generally recovers twice as fast as electric, unless the electric is a tankless and your supply water temps from well/city is warm. Around here water is 45 or so out of the ground to 70*+ rise takes a while.0 -
We have good water here. Tankless electric would require a significant electrical service upgrade.0
Vaughn has an indirect water heater that they can put an electric element in it. You can run the indirect water heater from the boiler during the heating season and electric element during the non heating season. Also if the boiler goes down during the heating season you can still make domestic hot water with the electric element in the indirect water heater.
Where are you located at?1 -
I am in RI. I actually just e-mailed Vaughn . Do you have experience with this type of setup?0
@Jon_blaney, you have to use a fuel source one way or another. Don’t get caught up thinking your boiler is “on all summer.” It’s not heating your home, it’s just satisfying your domestic hot water needs. A Btu is a Btu no matter the fuel source. Keep it simply: indirect off your oil fired boiler.2
I'll +1 @Danny Scully. Do the math, especially with a boiler like the EK, or any triple pass with a well insulated indirect & piping. If your boiler ran 1/2 hour a day to make DHW, and your firing at 1gph (probably less unless you're in a large home), that's about $1.50 a day, max $45.00 a month. Electric won't be cheaper unless you have really cheap rates. I'd only consider the 'electric' element route if I could tie that into some solar...but the cost...oh the cost.
And I'll agree with @Danny Scully and @STEVEusaPA -- and add one other comment. Occasionally heating the boiler will reduce condensation and corrosion in it.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England1
- 116 Geothermal
- 169 Indoor-Air Quality
