parallel and counter flow for one pipe steamer
newagedawn
Member Posts: 586
did some customizing on an ole one pipe steamer, cut out like 40 feet of return and turned a main into a counter flow, but kept the other main parallel
"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
How are you going to skim?New England SteamWorks
newenglandsteamworks.com0 -
like i always do, running the water slowly out the skim port after a week of operation, but if you noticed the gas valve isn't even hooked up yet, so be hard to skim it,lol"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
I think @New England SteamWorks was suggested he doesn’t see a skim port. Normally on those side outlet boilers you would install a tee there for skimming, or a nipple and cap on the other side if you’re not using both risers. I guess we’re just not seeing it in the pictures.1
- 15.8K Strictly Steam
