parallel and counter flow for one pipe steamer
newagedawn
Member Posts: 586
did some customizing on an ole one pipe steamer, cut out like 40 feet of return and turned a main into a counter flow, but kept the other main parallel
"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"
How are you going to skim?New England SteamWorks
newenglandsteamworks.com0 -
like i always do, running the water slowly out the skim port after a week of operation, but if you noticed the gas valve isn't even hooked up yet, so be hard to skim it,lol"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
I think @New England SteamWorks was suggested he doesn’t see a skim port. Normally on those side outlet boilers you would install a tee there for skimming, or a nipple and cap on the other side if you’re not using both risers. I guess we’re just not seeing it in the pictures.1
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
