Looking for an old angle valve for steam radiator
Lev77
Member Posts: 55
Hi all,
I'm looking to replace this old valve which has a damaged thread.
I've looked in a plumbing supply house, and online.
To my naked eye, the type of union connection that's here is not available online, but I could be wrong.
Maybe I just don't know the right name of this type of valve?
Any advice would be greatly appreciated.
I think the valve and spud need to be changed...New England SteamWorks
newenglandsteamworks.com-1 -
Looks like an internal pipe wrench should help get that spud out (and another one in). I'll give that a shot, would rather not risk having the radiator leak.
Thanks for the help guys!0 -
Well then, @nicholas bonham-carter , you were not joking
Thanks @Newagedawn, it was a 1 1/4.
After the rusted inner edges of the spud just got shaved off by the inner pipe wrench, I had to resort to drilling the side of the spud from end to end, hammering a demo screwdriver in there, then using the large pipe wrench on the screwdriver to force the spud to turn. It did budge eventually and here it is
Thanks again all.0 -
Do I use tape on the spud/valve? pipe dope? nothing?0
I've not done this but from what I gather you would dope the male threads, possibly lay some wicking in them first if you think they need that, and leave the mating surfaces as is - nothing on them. Someone can correct me if I'm off ...0
A picture is worth a thousand words! Good idea about the drill and screwdriver.—NBC0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
