How's this for a before picture?
Steve Minnich
Member Posts: 2,868
Forget the horrible workmanship.
Two flat plate heat exchangers - both piped wrong.
Two pumps pumping directly toward one another.
A basement radiant zone without heat for 12 years. It had a Honeywell zone valve that was replaced 3 times but it never had any circulation because it didn't have a pump. Never. Ever. Not one contractor mentioned that.
6 bathrooms all on separate zones with the smallest bathroom being 48 sf.
This picture really doesn't do it justice. It's some of the worst I've ever seen.
Steve Minnich
3
Can we see a picture of the ductwork too?
I want to see that mess as well.
That's a wild one. I've never seen anything like it.0 -
Looks like a supply house.........
And why were you called0 -
The sheet metal was actually pretty good. It couldn't have been the same guy.Steve Minnich0
12 years. smh0
Break out the Sawzall................All Steamed Up, Inc.
Consulting1 -
Looks like you might have some nice components from the rip out. What was the original installer using the flat plate heat exchangers for?0
At least it’s only 17. Tell your knees that0
One was for a relatively small snowmelt between two 2.5 car garages and the other was for a room above the driveway between the house and one of the garages. Exposed floor with radiant heat.Steve Minnich0
Hey....didnt @Gordy put that boiler in before he made the official switch to scorched air!Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1
Gordy and Stephen, I cut way back on wheat, dairy, and other foods that cause inflammation, and my joint pain is all gone, my knees feel better than they did 25 years ago...To learn more about this professional, click here to visit their ad in Find A Contractor.4
working alone is usually good until you rip a boiler out, getting someone for part time saves time and money , your back and knees"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
After photos?0
Looks like one of them there alum.block boilers so maybe just cracked on its own. Also can't tell for sure if extrol tank was in the system if main pump had check valve in it.0
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
- 45 Industry Classes
