LOCHINVAR® EXPANDS CON•X•US™ REMOTE CONNECTIVITY PLATFORM
HeatingHelp
Administrator Posts: 723
Where can I find a PC Web interface for the Con-X-System. We have a system at our church and need to install the interface on a fixed PC.0
I'm not sure there is a PC-based interface for it. The Lochinvar rep I asked didn't seem to think there was. All the info I've found is mobile-centric. Which is too bad because the app's information screens are bigger than my teeny-tiny iPhone display screen and some of them don't scroll. Frustrating! Just got the board installed today. Really promising idea for remote trouble-shooting, if it is reliable and learnable.0
You should check with a local manufacturers rep. I know they USE to have an onsite access port, not wireless, that could be plugged into a local PC using cat 5 wiring. You might have to have a signal repeater to make it work, but I did it with my Lochy before I put the Conexus board on it. It's the old program that was used for doing programming in the field. Required you to plug your laptop PC into the front of the control board.
ME1
- 120 Geothermal
