Lovely Plumbing.
I don't want to count all the joints.
Crappy water pressure. I have a theory that there may be corrosion buildup inside contributing to it as well
https://youtu.be/xszZCv7DVw4
Homeowner, Entrepreneur, Mechanic, Electrician,
"The toes you step on today are connected to the butt you'll have to kiss tomorrow". ---Vincent "Buddy" Cianci
First thing to check is the whole house water filter if low
H2o pressure. Either remove or replace filter housing or install a bypass around it. I would invest in a 0 to 200 lb pressure gauge with a garden hose adapter and check at the boiler drain right above the filter0 -
Looks like a Dahl mini ball valve? Some versions have a very small port, that would add some pressure drop. I suppose it could be partially blocked also.Bob "hot rod" Rohr
Living the hydronic dream0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
