Lovely Plumbing.
I don't want to count all the joints.
Crappy water pressure. I have a theory that there may be corrosion buildup inside contributing to it as well
https://youtu.be/xszZCv7DVw4
https://youtu.be/xszZCv7DVw4 Homeowner, Entrepreneur, Mechanic, Electrician,
"The toes you step on today are connected to the butt you'll have to kiss tomorrow". ---Vincent "Buddy" Cianci
Looks like a Dahl mini ball valve? Some versions have a very small port, that would add some pressure drop. I suppose it could be partially blocked also.Bob "hot rod" Rohr
Living the hydronic dream0
