Convector steam supply valves
Andy Stack_3
Member Posts: 39
Just a question
does anyone know if someone makes a 3/4" convector steam radiator valve i can only find 1" and 1-1/4"
thanks
thanks
Is this A two-pipe system? You could probably use a 3/4 gate valve with the stem horizontal.—NBC0
The valve looks like this but i need 3/4"
thanks
What’s wrong with the old one. Most of them can be repaired/repacked.—NBC0
Is this a 2-pipe system?0
- 120 Geothermal
