Boiler Change Out
Dan Foley
Member Posts: 1,268
We replaced this 50 year old Crane boiler in Rockville MD yesterday. The block was leaking. The pump flange is cast into the boiler section. One stud had broken off. Rust was holding it together.
The pump coupler was broken. You could hear the noise through the entire house. This one has earned its retirement.
2
We worked with my good friend Jimmy at Alpha Plumbing on this one. With two crews, this was was up and running by 2pm.2
Hey, it lasted 50 years! No one can complain.0
This. Also, one of my neighbors has a Slant/Fin "100 series" boiler, from the early 1980s I believe. It looks exactly like this one, except for the jacket color which is the usual S/F gray for that era. They apparently continued making this boiler for a while after they bought the Crane boiler operation in the early 1970s.BenDplumber said:Nice looking installation dan,Joe and jimmy
Consulting0 -
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
