Mixing valve recommendation
I like the CASH ACME. IDK the model number off hand.
We've had no issues so far.Bob Boan
Take a look at the Caleffi 520. It does have 100% shutoff so no temperature creep when a recirc pump is added.
https://www.caleffi.com/sites/default/files/file/na10482.pdfBob "hot rod" Rohr
Living the hydronic dream1 -
I love the Honeywell AMX myself, nice straight through design to screw on the factory WH nipple and an easy crossover with unions for the cold and mixed ports. Never had any trouble with them in the 8-10 years I've been using them. Webstone on the other hand, seems every second or third one I get is goofy and needs serious adjustment out of the box3
If you have hard water, it can clog up the mechanism. I think Caleffi has a coating to help prevent this.0
Thanks all.0
- 120 Geothermal
