Left & right bushing
Dan C.
Member Posts: 248
Which side of a left and right bushing has the left hand thread?
I am not sure if I have ever seen a left-right bushing. You can usually tell by looking at the threads which is the left hand side
I have seen plenty of left-right couplings.
The end that is left hand usually has a line or other marking on it0 -
Left and right bushing. They used to use them on radistor valves. I think the femsle side is the left hand but I haven’t worked on one in a long time.0
It depends on which side of the radiator your standing on.
Are you in the southern hemisphere?
Bizarro World?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
