Off Grid Direct Vent Furnace
Zman
Member Posts: 7,611
I have a project involving an off grid structure and I need to find a small direct vent furnace.
The problem I am having is that all the direct vent models I can find go straight out the back. Due to high snow levels, I need to go either through the roof or snorkel up and out.
Requirements:
Direct Vent (no combustion air from space)
Runs without electricity
Approx 15,000 btu/hr.(before alt deration)
Able to operate at 11,000 feet
Can mount on wall or in middle of room
Propane
Thanks in advance
Carl
Requirements:
Propane
Thanks in advance
Carl
Albert Einstein
Albert Einstein
look at direct vent gas logs.. if you add a chimney they can direct vent with twin pipes.. or can raise up off the unit a certain distance and the go direct out the wall at a higher level0
I don't know if this suits your conditions but Beckett makes a D/C powered oil burner. Gas, I'm not sure. Beckett fresh air kit. You can't do a B vent or triple wall? Must be direct vent?
Personally, I never thought there would be an application for a D/C burner. What powers the distribution?0
- 62 Biomass
