argo 822
hunter1
hunter1 Member Posts: 1
i had a power surge And neither of the units light the green light when calling for heat or if i jump the terminals are the units fried or is relay bad i have power to the units be nothing works
  • DZoro
    DZoro Member Posts: 1,048
    If you have 120v supply to them, and there is no fuse blown in the unit, I'm not sure if there is a fuse in that unit. It could very well be fried. Transformers/electronics don't do well with extreme or low voltage issues.
  • STEVEusaPA
    The relays are replaceable
    Jamie Hall Member Posts: 27,375
    Yes... but if there are any electronics on that board, the whole thing may be gone. As @Dennis so cheerfully noted, modern electronics do not play well with power surges... hence surge arrestors.
  • STEVEusaPA
    I'd still pop one in to see if it worked. But I agree, if both popped, the whole unit is probably toast.
