argo 822
hunter1
Member Posts: 1
in Oil Heating
i had a power surge And neither of the units light the green light when calling for heat or if i jump the terminals are the units fried or is relay bad i have power to the units be nothing works
If you have 120v supply to them, and there is no fuse blown in the unit, I'm not sure if there is a fuse in that unit. It could very well be fried. Transformers/electronics don't do well with extreme or low voltage issues.0
The relays are replaceable
Yes... but if there are any electronics on that board, the whole thing may be gone. As @Dennis so cheerfully noted, modern electronics do not play well with power surges... hence surge arrestors.STEVEusaPA said:The relays are replaceable
I'd still pop one in to see if it worked. But I agree, if both popped, the whole unit is probably toast.
- 120 Geothermal
