Has Anybody Noticed If Newly Installed VXT Feeders Sound Louder Than Older Units?
Gordo
Member Posts: 857
The last few new VXTs we've installed have evinced a high pitched screeching noise when feeding.
I suspect that the recent redesign in the solenoid's flow restrictor is the cause. The older model didn't seem to make this noise.
Has anybody else noticed the same issue? Thanks for your time.
https://www.youtube.com/watch?v=wSoe13eSAT8
Had a similar issue with a McDonnell 47-2. Had too high flow velocity and screeched loudly. Pinched the supply valve back until the screeching went away. Still feeds fine.0
Sounds almost like the solenoid is hanging up.0
We had one that did that awhile back. Putting in a new one on Thursday, -I'll advise how that goes.New England SteamWorks
newenglandsteamworks.com-1 -
haven't noticed it...but there are benefits to being old and almost deafgwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.3 -
@STEAM DOCTOR : One customer can hear that VXT screech on the second floor when it goes off at 0400 hrs.
Fortunately, that system is tight and uses very little water.All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
With VXT's new flow restrictor, it might have lowered the pressure/flow/noise threshold. That is to say, it may be that at water pressures below, say, 55 psi, there is no screech.All Steamed Up, Inc.
@Gordo. Wow. Thats extreme. I haven't had an issue with the VXTS that I put in. That said, low water pressure is common in a lot of my service areas. I also do not put in an awful lot of them. I remove many more Auto feeders then I put in. I am not a big Auto feeder fan.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
