Which are the best models Pressurtrol for a residential steam system
acl10
acl10 Member Posts: 349
edited March 2018 in Strictly Steam
Which are the best models Pressurtrol for a residential steam system.
  • acl10
    I see a few on Amazon
    Honeywell PA404A1033 Pressure Trol HVAC Control
    HONEYWELL PRESSURETROL MODEL L404F 1367 for steam boilers 8PSI BQ
    Honeywell L404F1060 Steam Pressure
  • KC_Jones
    KC_Jones Member Posts: 5,739
    What is wrong with your current one? If it's broken just replace with a like model.
    2014 Weil Mclain EG-40
  • Fred
    Fred Member Posts: 8,542
    The PA404A1033 is the standard Pressuretrol for residential boilers.
  • acl10
    I wanted to know which one is the best. I have a pa404a1033. I wanted to see if there is a better one out there.
  • acl10
    edited March 2018
    I dont know how to test mine and see if its really working
    EBEBRATT-Ed Member Posts: 15,556
    L404F1367 would be better. If you don't know how to test your control you should call a professional. This is a safety high limit control.
  • the_donut
    the_donut Member Posts: 374
    Turn the boiler on and watch the pressure gauge. If the burner cuts out at the cutin pressure + differential pressure, then you know your pressuretrol high end is good. Leave the thermostat calling for heat. The pressure will drop. If the boiler kicks back on at your cutin pressure, the pressuretrol low end works.
  • acl10
    edited March 2018
    What is the difference between the PA404A1033/U - and the PA404A1009
    I have the 1009 on my boiler
  • AnthraciteEnergetics
    AnthraciteEnergetics Member Posts: 77
    The standard ones are fine. I've seen setups using Magnehelic gauges with the internal switches. As well as various industrial pressure switches. But it's best to stick with the Honeywells, for sake of familiarity and availability.
    @acl10 , why don't you just google the control #s and find out. that's what I do.
  • ridgedjimmy
    ridgedjimmy Member Posts: 1
    Wow!!.
    You can't ask questions like that.
    "Why don't you Google it.? Dummy."
    "Mind your own business, kid."
    "Don't worry about it. Jerk"
    " There are no stupid questions, only stupid people."
    And "Don't ask ,don't tell"
    Sums it up nicely.
