Question on a 1984 Weil McLain Boiler
LifeWhere
Member Posts: 2
I'm monitoring a 1984, Weil McLain boiler. The unit turned on 40 hours ago and hasn't turned off. It turned on on 2/28 at 5:00 PM and is still running as of 3/2 at 9:00 AM. The first graph shows the unit turning on at the 20.6A capacitance spike and running for 40 hours (the timeline is 48 hours). The second graph shows a 6 hour window of time. It is running on a cycle where every 10 minutes it increases its draw by .2A (2.0A-2.2A total) every 4-5 minutes.
What should I look for to understand why it won't shut off?
What else is it doing, besides drawing 240 watts from the power line? Stand next to it and figure out what it's doing, please...Br. Jamie, osb
Jamie, we can't get onsite until this weekend. We are monitoring it remotely and working to see what we can detect before we show up.0
This being a steam boiler, could the pressure switch be cycling the gas valve? Tstat is still calling for heat. Flue damper stays open.
Or if an old school tstat the heat anticipator is out of wack.
With all this high tech monitoring do you know the average air temp in the building?0 -
Was this mystery ever solved....the weekend has passed.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
