Anyone know who made this thermostat?
Those people should advertise here!—NBC0
I have a Honeywell t105 chronotherm thermostat that I purchased at habitat restore several years ago. At that time I found the schematic online, I think here in Heating Help. Now, I cannot find it anywhere. I do find some old posts with links that no longer work.
My understanding of the old 3 wire thermostats is that they were a double through type of switch. I cannot see that in this thermostat, although it does have 3 wire connection on the back, plus 2 wires to operate the clock.
My T105 is still in the box, has installation instructions with a 1941 date. Any help would be appreciated.
DaveDave in Quad Cities, America
http://grandviewdavenport.com0 -
I answered my own question on this. Here is the information. I think the three-wire setup is really cool in the way it activates the heat anticipator heater ONLY as the room temperature is approaching the setpoint.
Innovation serves to fill a pressing need.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
