Anyone know who made this thermostat?
2»
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    A few pictures of old Honeywells:
    http://www.prothermostats.com/history.php
    Turbo Dave
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,362
    Wow! That's neat, Nicholas. Thanks for sharing.
    President
    HeatingHelp.com
    LS123
    Those people should advertise here!—NBC
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    I have a Honeywell t105 chronotherm thermostat that I purchased at habitat restore several years ago. At that time I found the schematic online, I think here in Heating Help. Now, I cannot find it anywhere. I do find some old posts with links that no longer work.
    My understanding of the old 3 wire thermostats is that they were a double through type of switch. I cannot see that in this thermostat, although it does have 3 wire connection on the back, plus 2 wires to operate the clock.
    My T105 is still in the box, has installation instructions with a 1941 date. Any help would be appreciated.
    Dave
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • LS123
    LS123 Member Posts: 476
    those are beautiful! and part of history... hang on to them!!! they would still work as Dan mentioned.... Man.... I wish I had them... My Ptrol 70+ years still works like a new one....
    Thank you!
    @LS123
  • Dave in QCA
    I answered my own question on this. Here is the information. I think the three-wire setup is really cool in the way it activates the heat anticipator heater ONLY as the room temperature is approaching the setpoint.
  • HomerJSmith
    HomerJSmith Member Posts: 2,701
    Innovation serves to fill a pressing need.
